3rd Gen guy needs 4th Gen help with ABS Brake unit
From my understanding my 2002 3rd Gen shares a similar ABS/Master Cylinder with your 4th Gens.
Symptoms: Prolonged motor cycling-whirring sound upon startup. Squishy brake pedal and rig lurches forward when almost at a stop, while making motor-whirring sounds.
Physically inspected all connection harnesses at the ABS unit as well as speed sensors at each wheel and they seem to be fine. No breaks etc.
Picked up a complete ABS/Master Cylinder unit from a local guy for $150 so I'm going to swap it out to see if it helps.
When I changed my brake fluid last year I just bled the system old school. I had no idea that I needed to trip the ABS actuators so it's probably why my brake pedal is still squishy.
Is there a less expensive option to trip that ABS actuator, to 100% bleed, other than purchasing a scanner with ABS auto-bleed option? (Which is like $200)
Also I read something about zero pint calibration and I'm wondering what that is and if I need to do it.
Any help appreciated
02 Thundercloud Sport, 155k.
