Originally Posted by phattyduck
I'm surprised it lifted the front end that much too! I don't expect it to settle, as they are your original springs, right? Maybe some smaller spacers are in your future...
And you can see the difference in the extended length of the new shocks there, compared to stock...
Yup, original springs, not much settling to be expected there for sure. One area where it might settle a tiny bit is that there was a permanent indentation in the rubber spring isolator under the mount from the spring end. I rotated the isolator so that a undented portion was now under the spring end, but the indentation was no more than about 1/8". So not much to be gained there.
Good news is that if/when I decide to use a smaller spacer, I won't have to undo the spring from the shock, just drop the whole assembly and slide in a new spacer. I can almost do that with my eyes closed now.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
