View Single Post
Old 11-12-2019, 12:22 PM
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner will become famous soon enough 81runner will become famous soon enough
81runner's Avatar
Real Name: Elliott
It is my understanding that you would only need control of the solenoids if you replace the cylinder and don't bench bleed first prior to install. I bled my brakes a few months back the OG way, and I have had no issues. To me, it sounds like the seal on the piston in your master cylinder may be failing, and you're losing brake pressure as a result. Did you have the same symptoms prior to flushing?
As to your question on zero point calibration: unless you replace an electrical component of the ABS system (including the cylinder, I'm assuming) your ABS computer will see this and throw out a traction control light, which you would then need to calibrate to correct. Even when tripped, the brake system on 4th gens still works as normal minus ABS. So I don't really think this is your problem
2007 SR5 V6 4WD, Titanium Metallic. 5100s, OME 885/895, extended rear links, Cooper ST Maxx 255/75 R17 on 17x8s, mud flap delete, throttle body spacer, Cold Air Intake, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, COB LED drop-in lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, Rigid Armor tire carrier, SE hood w/functional vent, Pedal Commander, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v hookup, dash mounted tablet, rear diff breather, pck, Freedom UCAs, custom stereo....for now....
81runner is offline   Reply With QuoteReply With Quote
Copyright © 2019
