Lines are bled, rears are adjusted, and as far as I can see, they aren't leaking.
Keep in mind this only happens during a hard stomp on the pedal. Pedal only looses boost then.
Tonight, I will try to get my hands on a vacuum gauge, or switch some hoses around, to see if the booster is getting the right amount of vacuum. Will report back.
spartacus
When your check valve went bad, was your hard pedal intermittent or constant?
THanks!
