Originally Posted by hinmo24t
I didnt know that...so the options from dealer are drain/fill, exchange, and flush? Thanks. They told me not the flush obviously and quoted me the $97 for drain and fill I guess which might be all im really looking to do.
usually its just a drain/fill or exchange, some say a true flush on high mileage engines can cause issues. the trans takes like 13qts of fluid so a drain & fill is only replacing a small amount of fluid. you can do a few over a couple weeks time to get more new fluid in there. but the exchange using the transmissions pump to pump out old while you refill with new is very easy, you just need a jug, a clear hose & a funnel. search 4runner transmission fluid change on youtube or here to see how easy it is. either way you go will be good for teh trans.
