View Single Post
Old 11-16-2019, 07:39 PM
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears will become famous soon enough 3bears will become famous soon enough
Originally Posted by alumarine View Post
It's most likely the Vacuum Check Valve on the brake booster part no. 44730-60060.
It could have had moisture in it.
I sprayed the inside with silicon lube last winter after it acted up.
Haven't had trouble since.
It does get your attention though!
thanks
well I just so happen to have another check valve I pulled out of a parts car....and it acted up again this morning, so I will give it a try.
just got to find the part ...if not Ill get a new one.
when you said sprayed inside....do you mean in the check valve....maybe I will do that too even into the replacement
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Copyright © 2019
