Originally Posted by firebirdguy
usually its just a drain/fill or exchange, some say a true flush on high mileage engines can cause issues. the trans takes like 13qts of fluid so a drain & fill is only replacing a small amount of fluid. you can do a few over a couple weeks time to get more new fluid in there. but the exchange using the transmissions pump to pump out old while you refill with new is very easy, you just need a jug, a clear hose & a funnel. search 4runner transmission fluid change on youtube or here to see how easy it is. either way you go will be good for teh trans.
Thanks. Im tempted to for sure and i hear you. Essentially they cant just drain and fill more than about 25% of the fluid at the dealer visit it seems...
