Originally Posted by AuSeeker
Just an FYI on the repair kit mentioned in this topic and the linked reference topic, according to the "check fit" on Amazon this part/repair kit is for the V8 starter and it says does not fit the V6 starter...but as the OP in the linked reference topic shows it will work for the V6 starter, I do see a small difference in the old parts/contacts and the contacts in the kit but apparently not enough of a difference that it won't work in the V6 starter, but it would be better to have the correct kit for the V6.
I did a little searching and the correct kit for the V6 is the Victory Lap ND-36SOL Solenoid Repair Kit, the difference in the part number for the V8 is 34 instead of 36 for the V6 in the part number, this is the part number for the V8 Victory Lap ND-34SOL Solenoid Repair Kit, both kits are the same price.
Here's a link to the kit for the V6 repair kit.
https://www.amazon.com/Victory-Lap-N...16430482&psc=1
Here's a link to the kit for the V8 repair kit.
https://www.amazon.com/Victory-Lap-N...ype=automotive
Originally Posted by Mantilgh
Interesting, thanks for the correction.
Doing a bit more research using the Amazon "check fit" function it says that the Victory Lap ND-36SOL Solenoid Repair Kit will fit both the V8 and the V6, it's strange that is the case since it says the Victory Lap ND-34SOL Solenoid Repair Kit won't work for the V6 but as we know it does seem to work Ok for the most part.
I also looked at new starters for both the V6 and the V8 and they both look much the same except the mounting flange is at different angles, so I don't see why the solenoid kits would have to be different, IMHO, but either way one of these 2 kits should work for either engine.
