View Single Post
Old 11-18-2019, 12:58 PM
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
Originally Posted by zonzin View Post
Followup question, the STL file has 2 builds for the part, which do I use?
There should be two different stl file versions (r5 and r7) on Thingiverse, each with a single part. Are you seeing more than one part in one of those files?
r7 is for if you can pass the connector end of the mic through the mount first (mic goes in from the bottom). I recommend r7 if possible.
On r5, the mic enters through the top, and you don't have to put the cable through first. On this design, the mic fit is pretty tight on purpose since the Kenwood mic has a taper which makes fitment difficult. The mic holding tabs are also prone to breakage on this one if you aren't careful.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
