Originally Posted by Gtbone
Greetings I have a 2006 Toyota 4Runner SR5 sport. It has the xreas system which is going to be removed looking for a shock recommendation for front and rear. Also the tires that I had on the vehicle were 265 70 R17AS I replaced them with 265 70 R17 AT. The clearance is good and I have no rubbing but the front tire looks a little stuffed. Im going to add a 1.5 level kit up front. The question is do I need to add a differential spacer with this size level kit?
Thanks!
Nope. Definitely not. On our 4th gens, the diff drop is pretty much unnecessary unless you want to run like 4, 5, 6+ inches of lift, above the norm!
I have Fox shocks and struts on mine and they treat me well for daily driving and getting off the beaten path, but the Bilsteins are most popular.
