Real Name: Ron
Real Name: Ron
If you're looking at mods, and this is primarily an offroad vehicle, consider an automatic locker. Automatic lockers are pretty cheap ($300) and you can install one yourself. The 2nd gen has fairly limited suspension travel, so it's easy to lift a wheel on opposite corners and get hung up on even mildly uneven terrain. A locker on either end will pretty much eliminate that issue.
If you don't plan to use it much on the highway in snow, install manual hubs ($100 for an Aisin set on ebay) and put the autolocker in the front. That's what I did (see signature), and I love it. Drives totally normally on the highway in 2wd with the hubs unlocked, and goes anywhere offroad locked in 4wd. The front locker makes it a handful when street driving on snow/ice, though.
I'd do the locker before the winch, for sure. I still don't have a winch - haven't really needed one.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
