Originally Posted by BackOff
Pulled the thermostat out to flush cooling system.
Have to pull T-stat apart because it is built into the housing.
I think the jiggle valve was at 12'o clock/top side... only getting back 3rd gen search results, they seem to be in the 6'o clock position.
Anyone have a 4th gen T-stat on the bench you can check?
Guess i can get a new one...
Yes put it at the 6 o’clock position. It will/should run about 10-13 degrees cooler!!
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
