Originally Posted by jross20
Oh that is a good idea. I will need to get a taller jack to do that. Can I lift her by the tow hitch?
Would probably be best to lift from the rear diff then set your jack stands under the frame. You can lift from the tow hitch but if you meant lifting from there to let your axle droop without jack stands, I wouldn't do that. Relying on a jack alone without jack stands could turn into a very bad day.
