Originally Posted by Spec-7
Referencing your first picture and noticing the garage door height, if you plan to continue parking in the garage you might want to make sure that you can clear the garage door. The new suspension, lift, and 2019 TRD Pro roof rack might create a clearance issue. Just a thought.
I normally park outside. I only parked in the garage to install the led interior lights. I was shocked that the length fit as I have cabinets attached to the wall taking up ~ 2’. Putting on the pro rack will most likely happen after the suspension. Once the rack goes on, I doubt I’ll be able to enter the garage. I may be like 1/2” clearance. But my gen4 spent all of her life outside. Currently my gen5 also stays outside [emoji2957]
