Originally Posted by royal T4R
Too high of a CV angle after lift install
The 885 coils will sag once you add weight.
Coil specifications:
OME 883: 375mm in height, 590 pound spring rate
OME 884: 390mm in height 590 pound spring rate
OME 885: 395mm in height 590 pound spring rate
OME 886: 402mm in height 660 pound spring rate
OME 887: 400mm in height 590 pound spring rate
OME 888: 405 mm in height 590 pound spring rate
Thanks for this.. doing the 885/895 combo.
