about an hour ago, I decided to disconnect the positive battery cable and clean off the terminal...no dice
then I disconnected the negative and tried to touch different pieces of metal to see if I got any life and no dice.
As a last resort I figured, why not jump start it since thats usually the most obvious problem.
As I went to the rear lift gate to get the jumper cables, the electronic latch for the rear gate apparently woke something up and the dome light went on inside.
Tried to start the car and it turned over and started....stalled right away the first time, but after that I was able to start it up about 5 times without issue.
Does the waking up of the electrical from trying to open the lift gate latch trigger any thoughts or possibilities?
