View Single Post
Old 11-24-2019, 09:16 AM
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I 2nd mtbtim mention of steering shaft pressure on rack, also providing everything installed properly. If steering shaft has extra pressure on rack, its really stiff. Happens to a lot of people doing body lifts also. So I'd loosen up the pinch bolt spine, lube it up, they can be seized too, may have to torch. You can take a long screwdriver with a hammer and wack up the pinch thing that holds the bolt if its not budging in the spline.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
