View Single Post
Old 11-25-2019, 04:32 AM
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by Charlievee View Post
I have seen the usb data link moved to the glove box from the center console, but has anyone installed a 12 volt power source or a usb charger that works off the "keyed accessory" while maintaining all the stock locations? I know the older model years have them, but the 2018 does not. Is there a plug and play option without hacking the harness?
There’s probably nothing that’s plug-and-play. If you’re not going to draw a lot of current, say to just charge a cell phone, you could tap off a parallel circuit from the existing accessory outlet. You’d have to get to the back of the 12 volt outlet under the radio, strip some insulation off of the two wires with a knife, solder (16-18AWG) wires to each, insulate them, and run them to the back of the glove box where you’d install a 12 volt outlet.
After a quick search I found this link that might help:
Help moving USB from center stack to glove box
Good luck. It’s not that hard but be careful and deliberate and do a clean job soldering. I like using this cable braiding sleeve to protect the wires from abrasion (TechFlex F6N0.25BK Flexo F6 General Purpose 1/4-inch Braided Cable Sleeve).
https://www.amazon.com/TechFlex-F6N0...4669837&sr=8-1
Anyone install 12v power in glove box(2018)?-1734fe9c-5ef3-4f75-b1c3-4d5b2645a204-jpeg
