Originally Posted by SeanWN86
Any ideas why I only hear it while braking?
And any other way to test/confirm/identify which? Other than the push and pull at the joint; which I'll do again and get videos to share.
it might be loading the joint just right to make the noise. typically that noise is associated with a tight joint, and will usually only make noise at low speeds. high speeds it goes away.
if it is a tight joint, you wont be able to feel it by shaking. you would have to drop the driveline. then check if any are stiff.
prior to that though, you can inspect the caps carefully. if any are showing red dust near the seal, that's the bad one.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
