Originally Posted by gamefreakgc
There's dye you can put in your oil that glows under a black light. You drop it in your oil, drive it around and let it leaks for a few days/few weeks or however long it takes. Then you get a black light and presto, there's your leak. No guesswork.
Good tip, thank you - I've used a similar product before to find a stubborn coolant leak, so I'm a believer. I ordered the dye, just because I am dying to know where the leak is coming from, even if I don't do anything about it.
Originally Posted by brillo_76
That's a very good question. I would think yes in time. Synthetic oil is great and far superior to conventional. The FIPG would break down in time just as our seals do.
I am just trying to help here.
I appreciate the help!
Originally Posted by LittleCaesar
Leon, is there any way you can get a pic under the balancer?
I have seen Rtv leak around pan bolts before over time, due to the torque displaced around it, and ultimately breaking it.
Honestly, I wouldn’t sweat it unless it got worse.
I'll have a peek there, not sure how much I can see without pulling stuff off
Originally Posted by mtbtim
I don't know where you read it would be a toss up between pulling the motor or removing the front diff, but that person had to be smoking some quality shit. No way in hell is this even a close comparison.
@ JZiggy
will tell you the same. Pulling the front differential isn't that hard if you release the driver side motor mount, jack up the engine a bit and then also release the metal vacuum and breather lines on top of the diff. It literally falls out if you do those things.
If Jordan said, "Hey Timmy, come on over to help me pull my engine so I can reseal my oil pan", I'd reply, what the F*@k are you smoking? I would never pull an engine on one of these rigs to do an oil pan gasket.
I know, I would expect the same - I'm just going by this thread, second post -
Easiest way to remove oil pan?.
Don't get me wrong, I am not pulling the motor, I just thought the discussion on that thread was interesting.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
