Originally Posted by Tyger255
Tried searching around for some info but no luck.
Ordered two need keys off amazon and had them cut today. I know they would not start the 4 runner because they are not programed so I tried them in the door with no luck. Then I tried the factory key and it would not lock or unlock the drivers door either. So I tried both keys in the rear hatch and the new and factory key both work with no issue. I tired the new key in the ignition and it would crank the 4 runner but because its not programed it would not start.
So, what is going on with the drivers door? It locks and unlocks with no issues with the remote, just will not lock or unlock using a physical key.
does it not turn?
most likely sticky tumbler inside. spray some lube and slide the key in and out
not go in?
spray lube and let sit
turn but not unlock?
need to remove door panel to make sure things are connected.
