Originally Posted by gSwift
I just swapped my stock TRDP exhaust with a standard exhaust from a forum member here. No issues with the swap as long as you swap the full exhaust from the muffler back. As stated above, the standard exhaust flange bolts to the tail section using 2 bolts. And the TRDP exhaust bolts to tail section using 3 bolts.
@ Brabbit
took some pictures with both exhausts side by side before we reinstalled them. I'm sure he will post up the pictures after he wraps up his Thanksgiving festivities
Thanks Gswift,
That’s what i was asking if you do the whole exhaust swap I did not think it would be a problem. Because if the TRD exhaust gets to be annoying then you can just swap it out like you did. Thanks for confirming that!! Also did you have any issues coming out where the tail pipe ends. Does it come straight out the back like the old Pro exhaust? Thanks
