Steel is going to be more rigid than the same thickness aluminum and from the looks of the both panels you can see the Rago cutouts are bigger and more numerous. The way these panels mount leaves a large, unsupported area so rigidity is desirable. If you plan to actually use these and load them up, steel is the way to go imo. If you are just after the look, sure, save a pound(?) and go aluminum.
My Rago panels also serve to constrain my cargo shelf side to side. The Rago panels have zero flex in them. This is one of the lighter loads. When I go out shooting I have ammo cans, tables and target stands on the upper shelf.
