Originally Posted by Off-Camber
Good call. I simply got 2 stainless bolts that had the same thread pattern, pumped a little clear silicone into the holes and then installed the screws. After cutting the rear plate light power wire it looks normal.
Totally forgot to mention that about the lights. I pulled the bulbs, but yeah it looked pretty silly with them shining on a missing plate.
How did this work for you? I thought about the same but the 1/2x20 lugs all showed a larger diameter where the knurling is so I wasn't sure how the 12mm logs would stay in place.
I honestly didn't even think to check the diameter, but I didn't have any issues. Knocked the old ones out, and ran the new ones in. I do have stud installer which seems to help keep the stud in place when driving it, but they seemed sug enough that I don't think it's needed.
Agreed with too many steps. They did change to 1 wing nut. I decided to use 1x 6 socket Weatherpak plug. Once the camera mount gets remedied I'll wire it up so I can unplug 1 plug in and everything is ready to pull apart.
Good to hear they updated it. And great idea on the plug. Let me know how it goes once they get your mounting situation figured out. I probably will be taking the loom apart and doing something similar.
