Real Name: Cas
Real Name: Cas
Sold!
SOLD!!!!!
Camelback Metal Rack
Description from TR4.org site
specs
3.5” x 47” x 88”
Weighs in at just under 70 pounds.
Sits ½” above the center of the roofline.
Slightly curved in the front, following the roofline. Unique shark fin antenna workaround found nowhere else. The design of this rack does not interfere with rear ladders.
Mounts to factory mounting points with supplied hardware.
Wind fairing also included. Full length and full mesh.
Selling because I just relocated to the DC area and the building I work at can not accommodate my vehicle in the parking garage. The rack has had tons of use. I have had it since 2014, so there is some wear as seen in the photos, the mesh could be replaced or just removed. I recently found the 2 crossbars it came with, however one side is missing the clamp. The rack was sprayed with rhino liner for added protection. The rack can accommodate a 40in light bar. Text me 972.814.eight.nine.eight.four
Whosoever is delighted in solitude is either a wild beast or a god.
