Originally Posted by Mbiker_101
Went to a quick change oil shop before heading out thanksgiving... they changed the oil and everything seemed fine when I drove off. But an hour later I noticed a low whistling noise coming from the engine compartment and under further inspection the air filter cover was open, and I noticed that they had broken off tabs to hold the clips to the airbox. Called them and they apologized and said they would fix it.... a couple zip ties later it was closed, but I still need a cover to the airbox.
Does anyone have a lid to the stock air filter for 2007 4.7 v8?
Thanks in advance.
Not your fault. Get that quick lube place to fix it to the way it was before you entered the shop doesn't matter if its $300 or $3000 it is the shops responsibility. Whats more concerning is that they let it go without even notifying you, and only told you when asked. Fixing it with zipties is not a solution. Otherwise i have a 4.7 2005 filter box i have lying around
