Real Name: Elliott
Real Name: Elliott
Originally Posted by blindloser1080
So if I'm reading it correctly, bank 2 sensor 2 needs to be replaced?
I would say both banks, start with sensor 2, should be past the cats. The computer uses both sensors to determine the amount of oxygen and unburnt fuel in exhaust. Sensor 1 is harder to get to, I'd try the easier accessed sensors first. Though you may want to just change all 4 since they work in pairs per the respective bank. Both short term trims are kind of high. Normal should be 0 to +-10, occasionally dipping up to 12 or so. Are you noticing a higher engine temperature? Common on older engines running lean, also common to have a rotten egg smell from the tail pipe.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
