Check the fluid level in the master cylinder reservoir. That light is usually associated with a low brake fluid level. If you're right on the borderline, it might be low when cold and immediately expanding a bit after you pump the pedal.
If you're consistently losing fluid, check connections at the lines you replaced.
Also keep an eye out for a sinking pedal, you should be able to stand on the pedal without it sinking. If it sinks, the cups in the master cylinder got scratched up during the bleed (if you bled by just pumping the brakes).
