Originally Posted by nobb
How is the AC compressor triggered? By the defrost button or a low temperature startup?
IMO it's a good idea to leave this alone because running the AC occasionally helps lubricate the seals and prevent failure.
I can’t really say how it get engaged but it will turn on automatically with the defrost.
You can still turn on the AC if the connector is unplugged by pushing the AC button. This mod gives more flexibility when using defrost. Also as mentioned why have the compressor on just to use more fuel if you don’t need it on?
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
