Originally Posted by Mike07SE
He's already past the range of suspension travel with the shocks he's using. If he were using shocks that were shorter in overall length he could probably stick with what he's got. Since his suspension is starting to bind with that setup, he should take it off and compensate for the lean by spacing a rear coil where there wouldn't be any adverse affect to the front suspension.
Hi. Just a follow-up. I ended up removing my front spacer and added a Daystar 1.5" in the rear left. Front has dropped a bit, but not much. Has more rake which I prefer. Also ditched the diff drop as my CV angles are much better now.
Now time for a re-alignment
Thanks for the help.
