Real Name: Ron
Real Name: Ron
Maxing out the caster with the lower control arm adjustments pushes the wheel forward, also contributing to your rubbing. While you're doing your next lift, you might want to consider after market upper control arms which will allow the extra caster you want while keeping the LCA adjustment roughly centered, and thus move the wheel back from where it is now.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
