Info for 2019 4Runner with
- updated P/Ns
- MSRPs as of Dec 11 2019
- links to parts.toyota.com for reference
Code:
item desc part/num
Engine Oil Pan Drain Plug 90341-12012
Engine Oil Pan Drain Plug Gasket 90430-12031
Front Differential Fill Plug Gasket 12157-10010
Front Differential Drain Plug Gasket 90430-24003
Front Differential Drain Plug 90341-24014
Front Differential Fill Plug 90341-18032
Front Differential (old p/n 90930-03136) Breather Plug 90930-03219
Rear Differential Fill Plug Gasket 12157-10010
Rear Differential Drain Plug Gasket 12157-10010
Rear Differential Drain Plug 90341-18057
Rear Differential (old p/n 90341-18006) Fill Plug 90341-A0002
Rear Differential (old p/n 90930-03031) Breather Plug 90930-A3001
Transfer Case (old p/n 90341-18006) Drain Plug 90341-A0002
Transfer Case (old p/n 90341-18006) Fill Plug 90341-A0002
Transfer Case (old p/n 90930-03172) Breather Plug 90930-A3005
Transfer Case Fill Plug Gasket 90430-18008
Transfer Case Drain Plug Gasket 90430-18008
Fluids:
2 (1.6) Qts LT 75w-90 GL-5 Gear Oil Front Differential
3 (2.8) Qts LT 75w-90 GL-5 Gear Oil Rear Differential
2 (1.1) Qts Toyota LF SAE 75w Gear Oil Transfer Case
7 (6.6) Qts Toyota OEM ILSAC GF-5 SAE 0w-20 oil Oil Pan
Code:
where used unique p/n count MSRP Reference Links
Oil Pan Drain Plug 90341-12012 1 $5.52 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG-PLUG-SUB-ASSEMBLY/62986468/9034112012.html
Oil Pan Drain Gasket 90430-12031 1 $1.13 https://parts.toyota.com/p/Toyota_2019_4Runner/GASKET/62973975/9043012031.html
Fr Diff Fill, Rr Diff Drain/Fill Gasket 12157-10010 3 $1.64 https://parts.toyota.com/p/Toyota_2019_4Runner/GASKET-PLUG/62915390/1215710010.html
Fr Diff Drain Gasket 90430-24003 1 $2.16 https://parts.toyota.com/p/GASKET/62986560/9043024003.html
Fr Diff Drain Plug 90341-24014 1 $11.32 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG/63351244/9034124014.html
Fr Diff Fill Plug 90341-18032 1 $7.41 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG/62981763/9034118032.html
Fr Diff Breather Plug 90930-03219 1 $9.68 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG---BREATHER-FOR-FRONT-DIFFERENTIAL/66841376/9093003219.html
Rr Diff Drain Plug 90341-18057 1 $12.24 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG-PLUG-SUB-ASSEMBLY/62986471/9034118057.html
T-Case Drain/Fill, Rr Diff Fill Plug 90341-A0002 3 $6.61 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG-FOR-REAR-AXLE-HOUSING-FILLER/63286991/90341A0002.html
Rr Diff Breather Plug 90930-A3001 1 $10.72 https://parts.toyota.com/p/Toyota_2019_4Runner/PLUG---BREATHER-FOR-REAR-AXLE-HOUSING/63154719/90930A3001.html
T-Case Breather Plug 90930-A3005 1 $2.44 https://parts.toyota.com/p/PLUG---BREATHER/69385720/90930A3005.html
T-Case Drain/Fill Gasket 90430-18008 2 $1.90 https://parts.toyota.com/p/Toyota_2019_4Runner/GASKET-PLUG-RING-SEAL/62973978/9043018008.html
tab delimited, copy to excel for better viewing.
Hope that helps someone out.
Please update OP as necessary.
