Originally Posted by gSwift
I have the Fox and they are fine on the street, can't really give much of an opinion on them off-road since i've only been on some light trails
I mainly want more lift/clearance and going with a long travel setup.
You must be talking about ICONs extended travel shocks which work within the stock geometry, I believe it just recovers a little bit of droop when using their upper control arms. Real long travel is something that completely changes the factory suspension geometry, replacing both upper and lower control arms, shocks, and front axles using a kit from Total Chaos or similar. It’s a significant cost and commitment for off-road use.
Seems like a awful lot of trouble for a little bit of lift, but I get it. You won’t see much of any travel difference between the two either with the ICON system. This goes for pretty much everything until you get into a proper +2 or +3.5 LT setup.
Let me know how much you want for the Fox shocks... ill buy the entire setup from you and throw them on my Limited.
