I've seen those search results you posted. For removal they basically say to remove the bolt, nut & locking plate and it can be pulled off. I've done all that, the problem is I'm having difficulty trying to pull it off the transmission which is why I asked how much force is needed to slide it off or if there's something else that needs to be done to remove the switch.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
