View Single Post
Old 12-19-2019, 12:51 PM
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Originally Posted by thobry View Post
Is there a difference in using a 300 amp M-series battery switch ($24 on amazon) vs a 100 amp 187 series circuit breaker switch ($52 on amazon)?
I see there’s a price difference but could I just use the M-series battery switch to disconnect my blue sea fuse box from the battery system in my 4Runner?
Thanks!
Sure you could use a switch as a disconnect, but the purpose of the circuit breaker is that it will trip if any piece of downstream work shorts out. It will prevent fires or damage.
Why not use a Maxi-fuse holder right off the battery? They come in 60, 80, not sure if 100 also, maybe. That will be cheap and still protect. Or put the maxi-fuse before the switch if you still want the on/off feature.
People go for the breaker as it is the neatest solution.
Edit: after looking at the 2 products, there is also the size factor. The switches are kind of big and bulky for under hood work. The blue seas breaker is smaller and neater.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
