Originally Posted by deanx2009
Hey Charlie, thanks for the input as usual. I haven't put in the 4wd rear uppers yet-probably will do that in a month or so.
The pinion angle will be off with the wrong rear upper links, and they may be making the issue worse.
Avoid driving at speeds that make the vibration as much as you can until you find the fix, otherwise you will be wearing out other components too.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
