Originally Posted by davidch
It seems to me that an ECU for a vehicle with a drive-by-wire throttle body - which to my knowledge is any 5VZ-FE 2001 and later - would differ significantly in its coding from an earlier my-foot-moves-the-throttle-plate engine.
And this is irrespective of whether the engine is mated to an automatic or a manual. Thus, the recommendation for a 2001 or later Tacoma ECU makes sense.
If you want to clear the check engine for CA emissions, you need a 2003 or 2004 MT Tacoma ECM. They are getting hard to find.
That's what I had to do on mine. Check out Tylers build he did a similar one to mine. I did not swap the wire harness. I just jumpered my AT harness and it worked just fine.
