Originally Posted by JoshuaZ
I saw in the suspension faqs that the 885 is what I would want stock, and 886 if I wanted to add weight(steel front bumper?) Aslo, do your 895e give you the 1in lift or are you able to keep it at stock height?
sounds correct with your first point and the 895e is their shortest rear spring i believe. its a lift spring and cant be stock height with my setup. you dont want to use the front bilstein 5100 adjustment notches with lift springs on them by the way. leave them at the zero setting - all the lift is from the OME springs. i got everything including new kyb tophats on Amazon for around $800.
