Power steering pump leak
Hi All,
Tried searching but didn't find much. I think my 08 V8 4Runner (105K miles) has a power steering pump leak. It doesn't seem like a common issue with these vehicles, so I'm wondering if anyone else had this happen to them? Two pics attached. I assume the pump is leaking. The alternator beneath it is getting oil on it. The valve cover above the pump is also slightly wet, but I think that's from the pulley slinging it around. Seem like the pump? Reservoir only has a slight reduction in oil. No hard steering, but i believe it does make noise on startup on extra cold mornings.
Thanks,
Brandon
2008 Limited V8 4x4
