View Single Post
Old 12-23-2019, 12:58 PM
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Originally Posted by qwertyisdead View Post
I’m mostly concerned with how I’ll retain the 02 transfer case.
Your transfer case will mate up just fine with the M/T. You don’t need to do anything special with the wiring, just re-use your auto wiring harness and cap the A/T plugs that are no longer used. That’s exactly what I did on my ‘99 Limited, my multi-mode transfer case works just like it did with an A/T.
Also, just re-use your old driveshafts. The M/T is 1.25” shorter than the A/T, there is enough travel in the slip yoke on the front driveshaft to compress it that much and I just put a 1.25” driveshaft spacer from Low Range Offroad on the rear driveshaft.
Look at my build thread for more info.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
