Originally Posted by brillo_76
Man I was hoping to see a 3rd gen be a ghost rider. Granted it's good to know only the rags will spontaneously combust.
in my previous life I was a wood working guy.
I have a lot of experience with BLO ( aka boiled linseed oil ) all modern BLO includes drier agents.
it's an oxidizing oil meaning it does cure just like any of the poly resins. it will start on fire. it's easy to do it, just soak a rag down and ball it up really really tight and put in a place like a fire pit?
there is a lot of confusing info out there on BLO but it's an old time finish and for exterior surfaces it's actually worse than putting nothing on at all. it's a terrible exterior finish. it's far too brittle and once cured cracks easily and traps moisture readily. It also encourages mold and mildew growth. it also lets moisture thru the cured surface film very easily.
the only reason I would put it on anything outside would be to accelerate the deterioration process.
to each their own but IMO it's not even a choice.
exterior surface finishes should remain flexible enough to expand and contract with the temps. if their was a magic old time finish that was cheap and easy we would still be using it.
