View Single Post
Old 12-27-2019, 06:48 PM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by TrexRunnerGirl View Post
Rear seat heater? You mean where the heat blows under the seat from the switch in the center console right.
Good to know.
Yes she will be sitting until I can fix it.
Those are indeed the coolant lines for the rear heat. You can search on here but the 01-02 rear heater lines are stainless steel and survive better if you're trying to replace them. Otherwise, like others have said you can loop the lines back to each other and your vehicle will be drive able until you decide to repair it. If you decide to bypass the rear heater make sure to top the coolant off after.
