Originally Posted by GRDPro
Well, you're in luck,
I did the same thing when installing my rack. I even munged the bracket spinning it with the last bolt. The good news is its recoverable! You will need to take apart some trim and headliner. The bracket I recovered was the rear passenger side. I did enough trim to access the front passenger side as well.
When you get the headliner slightly detached, you should be to reach in and grab the bracket and also the metal clip that holds the bracket to a metal piece connected to the frame. Just re-attach the bracket with the clip so you can get the bolts back in.
I left the trim and headliner off for a few days to verify that my seals were watertight.
Good luck!
Greg
Thanks Man, I really appreciate that! I will tackle that project next weekend.
Pete
