Real Name: Elliott
Real Name: Elliott
Neowedge Instrument Panel Gauge Colored Led Bulbs Lights Lamps | Autolumination
Been going nuts on this site, they have EVERYTHING. The console and climate control lights are 5630 style, t4 for the display, t3 for everything else. They work great, only thing you may need to do is take a small file to the fiberglass board the led is mounted to so it will fit in the hole provided. But beyond that, I've replaced all in the console display, and I'm currently waiting on my next order to update the buttons as well. Those are 5628 t3. Multiple colors, no issue with voltage, I have everything I've installed so far working. Nice to finally SEE the backlights in my buttons, even in daylight.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
