Real Name: Chris
Real Name: Chris
Originally Posted by sdkosu
I just changed my oil & filter, giving the Toyota oil a shot to see if it's worth the extra change and I picked up an aluminum housing as well. Noticed that it spun on much easier than stock plastic and I was actually able to fully seat the housing metal to metal. Same with the drain plug. I double checked the new o-rings and all. I ran the truck to see if any leaks appeared and it looked OK after a few minutes of idle. Did you have the same experience with the new housing or did it fit very snug like the stock plastic?
Metal housing is much smoother. Spins all the way down until the o ring seats and then I snug it. Much nicer install than the plastic housing.
