Real Name: Elliott
Real Name: Elliott
I don't really think a fuse is the issue. If there is a hairline crack, heat will build up as current passes over it and cause it to pop, in my experience. I would look at the harness connections, in particular the power and ground. If those are an issue, it could cut out. Just because it looks ok doesn't mean it's a good connection. Lightly tug on the wires and make sure they don't come apart. Bad grounds can cause all kinds of problems and in turn damage the radio, which may be the case.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
