Not sure exactly the extent of this issue here. Do your led lights come on at all? Are you saying your headlights stay on after locking with the fob? If that's the case, check your doors after Fob lock and see if any are unlocked. It would mean you need to replace the lock actuators.
If your only having issues with interior LEDs not working, always check the polarity is correct. Most leds can not be reversed but there are some that are designed to go both ways, giggitty. Check and see if your tail lights are still working as well. On my 4the gen I blew a tail light fuse which was also used for interior lights. Took a while to figure out that one. If you got a multimeter you can check and see if your getting power on the light fixture contacts. Remove led bulbs? Put OEM bulbs back? Unhook battery to reset? Sacrifice a goat?
Either way no more dad puns about light please.
2007 SR5 4WD Driftwood Pearl Totaled 2018
2014 Trail Premium with KDSS - Nautical Blue
