Originally Posted by Daftjungle03
I think most people seemed to be more concerned about moly vs. no moly for that portion. I've read a lot here and on BITOG forums and just came to to conclusion a couple of pumps for the spines is plenty. Since most dealers or lube shops wont probably hit them at all anyway. I just put the rig in neutral and roll it until things line up. I'm planning on doing it each oil change just to keep it simple.
you mean to say you're planning to grease the slip joint on the driveshaft at every oil change? if so, keep in mind that the grease doesnt really go anywhere or evaporate away, so eventually after not too many oil changes you will have pumped in too much grease & have an overfill situation. the slip joint isnt like a ujoint where you can flush out the grease as much as you want.
doing about 4-6 pumps is all the slip joint should need for a long time until it starts to clunk again & if its not making any noise now then a few pumps of grease is all thats needed for preventative maint.
