Real Name: Matt
Real Name: Matt
When I “refreshed” the suspension on my ‘98, I took a lead from some of the lift installations I’ve read through and loosened the pan hard bar bolts with the truck in the air. After installation of the new parts, I let the truck down and then re-torqued the bolts to spec.
I’m running rear moog springs on sen-sen shocks and have no lean.
Definitely take a look at the front as others have suggested before you assume it’s a problem in the rear.
My factory rear springs were identically color coded, I think it’s the front springs that we’re designed with different sizes to account for the asymmetric weight distribution
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
