Originally Posted by tacoyota
You are adding quite a bit of equipment up front. I recommend going with a 2.5 inch shock up front to control and dampening. Icon/King/Fox 2.5 up front with dobinson or eibach springs front and 2.0 shocks with custom lift/rate dobinson in rear. The eibach pro kit just came out so you might want to check that out for a step up from 5100s as well. I think they are still $700 right now. The 5160's tend to leak. If you are going to fork over cash, its better to skip the upper tier bilstein and use top tier name brand shocks. As for the lift height, most people seem to be fine lifting the front 2.5 inches on stock UCA's. You may want to just lift 2 inches to be safe if you want to keep a good caster degree to prevent squirrely driving if it is your DD. Hope this helps!
Thanks for the input. I've been looking at doing the Fox 2.5 up front and 2.0 in the rear but would I be able to do just 2 inches up front? I'd really like to not have to spend more money on UCA but understand if that is a necessity. I definitely will need good caster since it's DD.
